- Joined
- Jan 20, 2012
- Messages
- 3
- Reaction score
- 0
Hallo,
I need an answer about 3CX – VAD.
I bought the 3CX VAD with license and I need to use this software for inserting data from callers into DB.
I am asking : how can I get the telephone number of callers (from PBX) inside VAD ?
Note that I already used, as a test, the Database Control of VAD to insert some records into DB (and it run well).
Can you help me to get the caller number using VAD so then I can treat and store it?
Thanks in advance and I will wait replies.
