Get CSV info, script example?
Discussion in 'Call Flow Designer' started by VictorSP, Mar 22, 2018.
  1. VictorSP
    Sep 6, 2016
    55
    9
    Could anyone provide an example of script to get info from CSV, please? We want to check into the CSV the PIN and get the destination asociated. CSV example:
    PIN, Destination
    111,8899
    222,8888
    333,8877
    Thanks!
    Victor
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    908
    70
    Hello @VictorSP,
    Please take a look at the following article:
    https://www.3cx.com/docs/cfd-creating-phone-support-portal-3/
    The script there validates ID and PIN. You need to validate the PIN and return the Destination, so you can easily change the script as follows:
    Code:
    public string GetDestinationForPin(string fileContent, string pin)
      foreach (string line in fileContent.Split('\n'))
        string[] lineParts = line.Trim().Split(',');
        if (lineParts.Length == 2)
          string customerPIN = lineParts[0];
          if (pin == customerPIN)
            return lineParts[1];
      return "";
    Kind regards.
    VictorSP likes this.
  3. VictorSP
    Sep 6, 2016
    55
    9
