Get Dialed Number
Discussion in 'CRM / Helpdesk / App Integration' started by australian, Feb 25, 2012.
  1. australian
    Aug 20, 2008
    11
    Hi Guys,
    I need to get the number the caller dialed for an app I'm working on. is that possible?
    Not to be confused with the caller ID, but the number the caller dialed.
    Droyt
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You can easily get the extension number where the VAD callflow is registered. That is stored into the "session.dnis" variable. But the external number dialed by the user is a bit more difficult. You need to search into the CallHistory3 table (in the 3CX database) and correlate your current call with the right record using date and time...
    Regards,
  3. Ts2012
    May 5, 2012
    Was wondering if anyone knows about a solution that will enable us to get the phone numbers that our caller are dialing.
    We have many numbers and can't tell right now, which are being used for non-spam calls, and which aren't, etc...
    Please advise,
  4. VAD_Support
    Aug 6, 2009
    690
    From a VAD application you can do it reading from the CallHistory3 table (from the 3CX database). You would have to use a Database Access component to query that table and match the current call by ANI, date and time. Then you will have the number dialed by external users to reach your PBX.
    Note that this is only possible if you have digital or VoIP lines. With analog lines, you don't receive the destination number dialed by the remote user, in that case you just receive the call.
    Hope the information helps.
    Regards,
  5. Twilio
    Jun 26, 2012
    you can do this easily from VAD application........
    you just access your database component from the query and match your fields by call ANI......... no worry about it...... :)
  6. time-o
    Mar 24, 2011
    It would be great to get the 3CX CallID or HistoryID as a session variable. This would make my work much easier.
  7. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Agreed. Not having access to that ID value has made some things very challenging. Although I have plenty of workarounds for the limits of the VAD at this point, they're just not all ideal.
  8. time-o
    Mar 24, 2011
    Ich agree fully i have the same problems here.
  9. time-o
    Mar 24, 2011
    One Point: The callhistory3 record are created when the call is done. You have to use the api to get the current active calls and then you can use the dialed number in your workflow. I've made a service using sockets.
  10. fenta
    Jul 19, 2012
