Get log from 3CX v.15 Windows Client
Discussion in 'Windows' started by Johannes Sidarta, Mar 15, 2017.
  1. Johannes Sidarta
    Mar 15, 2017
    I'm having difficulty installing 3CX v.15 Windows client to Windows 8x64 professional.
    The installation was successful, but when I run the application, I can see "3CX 32-bit" process for 2 seconds from "Task Manager" but then the application is closed by itself.
    Is there a way to get the 3CX installation log? I looked for Windows Event Viewer and there is no 3CX reference anywhere
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Hello @Johannes Sidarta
    Please navigate to your installed programs (programs and features) and make sure that Microsoft visual C++ Redistributables for both (x86) and (x64) are installed (this is for v15 client). If not then you can manually download them from microsoft and install them. Let us know if that resolves your issue
  3. Johannes Sidarta
    Mar 15, 2017
    Hi Yiannish_3CX
    Thanks for your response, I have checked the computer, it already has Microsoft Visual C++ 2010 Redistributable - 10.0.40219 x64 and x86.
    Is there anything else that I need to check?
  4. YiannisH_3CX
    May 10, 2016
    7,326
    532
    Sorry i was not more specific, you need Microsoft visual C++ Redistributables 2015 x64 and x86 for the V15 client to work. Please install them and try again
