Get the filename / path of a call's call recording
Discussion in 'CRM / Helpdesk / App Integration' started by helia, Feb 16, 2017.
  1. helia
    Nov 1, 2016
    9
    Does anyone know how to get the filename of the call recording. Is it available via the API or does it have to be built based on a format. or make a call directly to the db? Also is the default path for the call recordings available?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,066
    75
    Hi there,
    Recordings are always saved in folder "C:\ProgramData\3CX\Instance1\Data\Recordings". The file name depends on the extension number, callId, etc, and can't be determined before the recording starts. You can check that folder and see some recording file names, to undertand the structure it has.
    Kind regards.
  3. helia
    Nov 1, 2016
    9
    So to confirm what you're saying, the file name for the recording is not available through the api as a parameter. The best that can be done is to estimate the correct file name based on the concat-ting the parameters that make up the recording file name.
    Its certainly not best practice but if it works....
    I'm presuming the 3CX official interface doesn't concat parameters on the fly to get a recording url. No experienced developer would do that. Is the static recording filename stored in the 3CX database and how much of a bad idea is it to get a readonly db connection and look up the static filename.
    #3 helia, Feb 16, 2017
  4. edossantos
    Jun 27, 2007
    1,066
    75
    The API just doesn't expose the recording file name information. The process responsible for the recordings has an algorithm to calculate the name of the recording for each call, creates the file and saves the information in the CDR in the 3CX database. This name is not exposed by any API, so you can basically do 2 things:
    1) You can look for a new file in the recordings folder, trying to match some of the paramters you have in the file name (extension, caller Id, etc.). Or
    2) You can query the 3CX database, but please note that the record will be inserted in the database a few seconds after the call has ended. And please also note that accessing the 3CX database is an unsupported procedure, 3CX can change the structure of the database at any time, and your implementation will be broken. Maybe you better get the CDRs from the CDRs interface: https://www.3cx.com/docs/cdr-call-data-records/
    Kind regards.
  5. icns01
    Jun 11, 2017
    18
    5
    Can you say what is the default storage locations for the Linux installation and if, for optimum performance, this be on a separate partition than the root "\"?
    Thank you.
  6. edossantos
    Jun 27, 2007
    1,066
    75
    In Linux the recordings folder is:
    /var/lib/3cxpbx/Instance1/Data/Recordings
    Kind regards.
  7. icns01
    Jun 11, 2017
    18
    5
    Thanks much. Appreciated
