Getting 1-way Audio
Discussion in '3CX Phone System - General' started by Daver, Apr 20, 2007.
  1. Daver
    Apr 20, 2007
    My 3CX is running behind a router that has DMZ pointing to it. Internal phones work ok. If an outside caller calls me, he can hear me but I can't hear him.
    I am sorta lost at this point after many hours of trying different thing...any help?? Thank you in advance.
  2. Anonymous
    Anonymous Guest
    Can be ports UDP 10000 - 20000 or codecs that has to be G711
    her are the full range of ports:
    UDP 5060 for sip
    upd 7000 - 7500 for internal extensions but need to be enabled if your device is external eg you phones are on the internal network and 3cx is on DMZ
    udp 9000 - 9003 for external these ports are used for inbound and outbound calls routed via the ATA
    udp 10000 - 20000 these are for your sound traffic or also called the RFC ports.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,916
    225
    One way audio means you have a firewall or network configuration problem
    You must install 3CX on the internal network, and then ensure your firewall is correctly configured (assuming you are using a VOIP provider). Use the server status logs to troubleshoot the problem.
    For future posts, specify what you are using to make and receive calls, and also post the server status log.
