Getting 403 forbidden for outbound calls
Discussion in 'iOS' started by ajaypadavala, Mar 25, 2013.
  1. ajaypadavala
    Mar 25, 2013
    Test: Trying to make calls from iphone using 3g data
    I have configured my 3cx phone system with DDNS as public IP. I have downloaded a Zoiper client and have given the following details:
    Domain - DDNS name -(for ex - test123.dnsd.me)
    Extension - 101
    Username - 101
    Password - password from 3cx phone system
    Auth username - 101
    Call Id display - test123
    I am able to successfully register with the 3CX phone system.
    When i try making an outbound call to another extension number , call is getting failed with 403 forbidden error after the 2nd Invite
    Ideally there should not be any issue with the authorization as i am able to register successfully. What else might be the reason for this ? It would be great if any one can throw light on this.
    Thanks,
    Ajay
