Getting an occasional echo during calls
Discussion in '3CX Phone System - General' started by Ralph, Oct 27, 2007.
  1. Ralph
    Ralph Member
    Jun 28, 2007
    417
    We have been getting an echo during calls every now and then. It appears that only we can hear it not the party on the other end.
    We are using 3CX version 3.x (latest). The server is dedicated with 1 gig of RAM, P4 3.0ghz CPU, and Windows Server 2003 Enterprise ed. We are also using Polycom Soundpoint IP 501 phones. QOS has been implemented on the network and there is plenty of bandwidth.
    Other then getting an echo every now and then the call quality has been excellent.
    Any ideas on how to fix this?
    Thanks again
  2. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    I also do get that now and again.
    I use both Sipgate.co.uk and my Astrisk installation at the office(Using TDM400 FXO)
    The echo is only for the first 30sec of the call and then goes away.
  3. weebnuts
    Sep 13, 2007
    37
    I get it as well, but not all the time.
  4. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good morning
    The echo occurs occasionally and now that I think about it, it does stop after a short period of time.
  5. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    I too get the echo and mine stops to after a short time. If you listen closely then you can hear a small hiss that fades out in a few seconds.
    Cjammer
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I don't get echos but has static or jitters. After a few seconds, under 30, it goes away.
    Does it take the sip packets a few seconds to find the best path or force QOS into action?
  7. paul@pcjen.co.uk
    Oct 8, 2007
    8
    Call Quality through Patton Gateway
    We too are also getting an intermittant echo/delay, this would appear to be mainly on calls through a PSTN to a Patton 4114 Gateway. Calls through SIP appear to be better quality. We are using Snom phones, a mix of 300'2 and 360's. We have disabled AntiVirus on the 3CX Server, any other things we might try please.
    Paul
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    Version 4 will help
    In our internal tests, it seems that 3CX Phone System version 4 will reduce echo when making calls on grandstream gateways. In defense of Grandstream, this does not seem to have been a Grandstream problem but more an interoperability issue. In cooperation with Grandstream we addressed this issue.
    Basically the way our new media server handles calls, has made a significant improvement in delay and echo issues.
    We hope to release a stable beta soon, over the next few days, and i recommend trying it out and seeing if echo has improved.
    In our tests in our live environment, there has been a significant improvement of the voice quality.
  9. fratan
    Feb 28, 2008
    I'm using a polycom 601 with the latest version of 3cx. I too have been getting echo only on my end. QOS has been set up on the router side. I'm thinking the audio processing on the g.711u and a needs tweaking. Has any one else tweaked the 3gx setup from the original config.
    thanks,
  10. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Echo is not a problem of 3CX or IP-phones. The source of the Echo is analog side of the call. You need to use voip gateway with good echo canceler and good analog equipment.
    Read this http://www.cisco.com/en/US/docs/ios/solutions_docs/voip_solutions/EA_ISD.html
  11. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX PBX is not a source of echo. All audio streams (which are handled by PBX) delivered "as it is". Any well-grounded reclamations will be greatly appreciated.
