Getting caller ID from "RDNIS"
Discussion in '3CX Phone System - General' started by hashkent, Apr 29, 2011.
  1. hashkent
    Apr 24, 2011
    5
    My provider sends the called DID in the SIP headers as "RDNIS", how can I extract this so that the call goes to the correct inbound rule?
    I've tried changing this to "Match any fields" under source ID without any luck.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, you would need to run wireshark so you can see what the VoIP provider is sending etc,
    if you can let us know the Provider, will see if we have any info about it.
  3. YellowLemon
    May 15, 2017
    Hi sorry to bring up old thread but I also have this question. Provider is MyNetFone in Australia. The "called DID" doesn't come through in the TO INVITE, but it is in the RDNIS
