Getting presence via call control API
Discussion in '3CX Phone System - General' started by jamesdawson, Feb 5, 2014.
  1. jamesdawson
    Jan 30, 2014
    21
    Hi, is there a way of getting presence via the call control API?
    I can't see anything in the help file from the examples. I've poked around using intellisense and just writing out various properties. I though that extension.userstatus might have given it me, but it only changes from available to away which is triggered by DND. I cannot detect if the user in on a call. I can see if the are registered or not, so I think it's only the on call / free line flag I need to find. is that available somewhere?
    or should I check extension.activeconnections and if there is any assume the user is "on a call"?
    code below:
    Code:
            public void GetqUsers(string ext)
                PhoneSystem ps = PhoneSystem.Root;
                foreach (Queue aq in ps.GetQueues())
                    if (ext == aq.Number)
                        foreach (DN amem in aq.Members)
                            Console.WriteLine("Q: " + aq.Name + " user: " + amem);
                            Extension anex = (Extension)amem;
                            Console.WriteLine(anex.Number + " users status: " + anex.UserStatus + " q status: " + anex.QueueStatus  + " registered " + anex.IsRegistered );
  2. dab
    dab
    Nov 1, 2009
    67
    Any update? I'm very interested in this feature too.
