- Joined
- Oct 16, 2014
- Messages
- 4
- Reaction score
- 0
Followed the admin manual but it is a little out of date as google has changed. All setup and have key etc but push not happening for android or iphone.
Project Number (GCM Sender ID) field is not a number from google either, in my case google provided "watchful-net-737" which I have used. Is this going to cause an issue ?
I have manually added an iphone and android device as they 'appeared' in the phones tab, I guess they were auto detected ?
Lastly, I couldn't see in the admin manual what number format to use for the 'mobile number' in the extension setup so used the standard country code, is this correct ?
So the above is problem 1, push not working for apple or android.
Problem 2, android or apple phones wont connect when using cell data instead of lan wifi. I have opened and forwarded the ports stated in this doc http://www.3cx.com/blog/docs/ports-used/ and the firewall checker is all green.
Checking a handset and it does have the correct public IP for external PBX and STUN server.
Any help appreciated, I want to work out all the gremlins before moving to a production environment as we have a _LOT_ of mobiles and I don't want to be playing around with each one manually like I'm having to do now.
thanks
thanks
