getting the DTMF tones
Discussion in '3CX Phone System - General' started by BrunoA, May 10, 2009.
  1. BrunoA
    May 10, 2009
    I would like to collect short data (3 digits for example) entered by the calling users, through the DTMF tones. I did not found a way to do this, so I made an IVR (extension 800), without any keys: when the calling user listen to the prompt, he enters his 3 digits; then I have to extract data from the 3cx logs. My questions are:
    - how can we get DTMF tones with a simpler method, without using an IVR ?
    - is it possible to lauch an specific program at end-call, giving to this program all the call data ?
    - the log 3CXPhoneSystem.log logs all the data (in this log, I entered 642 for example), but we can't access it through program (file allready opened by 3cx manager)
    - the log callhistory.log is accessible through program, but the 3 digits are troncated (first digit is dropped: 42 instead of 642)
    Thanks for answer, thanks for help.
    3CXPhoneSystem.log
    18:27:15.187|.\CallCtrl.cpp(524)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(41): Device joined: sip:800@127.0.0.1:40600;rinstance=d8ee38d467fbdb92<br>
    18:27:23.640|.\SLServer.cpp(773)|Log2|MediaServer|MediaServerReporting::DTMFhandler:[MS211000] C:41.1: 213.215.45.245:35398 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.<br>
    18:27:29.375|.\CallCtrl.cpp(295)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:642@127.0.0.1:5060><br>
    18:27:29.406|.\CallCtrl.cpp(404)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(41): Calling: VoIPline:42@(Ln.10001@ippi)@[Dev:sip:xxxxxxxxx@ippi.fr:5060]<br>
    18:27:29.937|.\CallLeg.cpp(232)|Log2||CallLeg::eek:nFailure:[CM503003]: Call(41): Call to sip:42@ippi.fr:5060 has failed; Cause: 404 Not Found - Invalid Speed dial; from
    callhistory.log
    1,20090510162714.609,0970cc469c199407,10001,800,33952900652,0427868001,1
    3,20090510162714.609,0970cc469c199407,10001,33952900652,33952900652,,1
    3,20090510162714.640,0970cc469c199407,800,,33952900652,800,1
    2,20090510162715.171,0970cc469c199407,10001,800,33952900652,800,1
    3,20090510162729.406,0970cc469c199407,10001,42,0427868001,42,1
    4,20090510162729.937,0970cc469c199407,10001,,42,,1
    4,20090510162731.578,0970cc469c199407,10001,,33952900652,,1
    4,20090510162731.593,0970cc469c199407,800,,800,,1
    6,20090510162732.187,0970cc469c199407,,,,,
