Getting this error while trying to call outside
Discussion in '3CX Phone System - General' started by almefab, Jun 26, 2009.
  1. almefab
    Apr 9, 2009
    14
    I am getting this error while trying to make external calls.
    CAn anyone help me what iam doing wrong. Also i did an outbound rule and set it this way
      File size:
      32.3 KB
      956
      File size:
      37.9 KB
      955
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello,
    it's spa3102 ? your gateway is registered ?
  3. almefab
    Apr 9, 2009
    14
    Yes my internet gateway is SPA 3102.
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    ok. do you try inbound call ?
    if it's work, the problem come from your configuration of gateway. (dia tone, frequency, voltage, etc...) what's your contry ?
  5. almefab
    Apr 9, 2009
    14
    intenally all works well. Our country is Malta (europe).
    Thanks for the help so far :)
  6. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    ok can you tri to call the gateway with an other telephone ?
    like this you try inbound call, throughout gateway.
  7. almefab
    Apr 9, 2009
    14
    Now it is working :D
    We are trying to call an internal line from an external laptop is this possible? and can anyone offer some help? (we are trying to connect from the laptop using an internal extension and its getting connected and make calls but no voice is being heard from it)
  8. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    ok in and out call works ? or juste in ?
  9. almefab
    Apr 9, 2009
    14
    Hey now everything is working our main concern is if someone calls and no-one is in office how are we going to foward it to an external number (mobile) ?
    15:46:48.234 [CM503008]: Call(21): Call is terminated
    15:46:48.234 [CM503015]: Call(21): Attempt to reach <sip:800@192.168.0.127:5060> failed. Reason: Server Failure
    15:46:48.234 [CM503003]: Call(21): Call to sip:9700@192.168.0.124:5061 has failed; Cause: 503 Service Unavailable; from IP:192.168.0.124:5061
    15:46:48.140 [CM503005]: Call(21): Forwarding: PSTNline:9700@(Ln.10000@Linksys GateWay)@[Dev:sip:10000@192.168.0.124:5061]
    15:46:33.671 [CM505001]: Ext.102: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.0.127:5060]
    15:46:33.656 [CM503002]: Call(21): Alerting sip:102@192.168.0.114:5060;rinstance=fe30e0453a42203d
    15:46:33.109 [CM503004]: Call(21): Calling: RingAll800:102Ext.102@[Dev:sip:102@192.168.0.114:5060;rinstance=fe30e0453a42203d]
    15:46:33.109 [CM503010]: Making route(s) to <sip:800@192.168.0.127:5060>
    15:46:33.109 [CM505002]: Gateway:[Linksys GateWay] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.0.127:5060]
    15:46:33.109 [CM503001]: Call(21): Incoming call from 10000@(Ln.10000@Linksys GateWay) to <sip:800@192.168.0.127:5060>
    15:46:33.109 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:800
    15:46:12.312 [CM504001]: Ext.115: new contact is registered. Contact(s): [sip:115@192.168.0.124:5060/115]
    15:45:26.953 [CM503008]: Call(20): Call is terminated
    15:45:26.953 [CM503015]: Call(20): Attempt to reach <sip:800@192.168.0.127:5060> failed. Reason: Not Registered
    15:45:26.937 [CM503016]: Call(20): Target is not registered: PSTNline:9700 dialed on (AnyLine@Linksys GateWay)
    15:45:26.937 [CM303003]: There are no available outbound lines on gateway Linksys GateWay at this time.
    15:45:12.406 [CM505001]: Ext.102: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.0.127:5060]
    15:45:12.406 [CM503002]: Call(20): Alerting sip:102@192.168.0.114:5060;rinstance=fe30e0453a42203d
    15:45:11.921 [CM503004]: Call(20): Calling: RingAll800:102Ext.102@[Dev:sip:102@192.168.0.114:5060;rinstance=fe30e0453a42203d]
    15:45:11.921 [CM503010]: Making route(s) to <sip:800@192.168.0.127:5060>
    15:45:11.906 [CM505002]: Gateway:[Linksys GateWay] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.0.127:5060]
    15:45:11.906 [CM503001]: Call(20): Incoming call from 10000@(Ln.10000@Linksys GateWay) to <sip:800@192.168.0.127:5060>
    15:45:11.906 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:800
    15:45:26.937 [CM303003]: There are no available outbound lines on gateway Linksys GateWay at this time. - when i got this error i putted the gateway to accept 2 simultanously calls. after i got a new error
    Thanks for the help
