getting user or phone status
Discussion in '3CX Phone System - General' started by simonatkins, Nov 2, 2011.
  1. simonatkins
    Nov 2, 2011
    9
    Hi, does anyone know how to get the status of a user using the 3cx .NET API? There's a userstatus property on the extension but this seems to return only 'Available' all the time even if a phone is unregistered.
    thanks
    Simon
  2. cloidhamer
    Jan 30, 2009
    36
    Public ps = New PhoneSystem
    ps.Root.Connect()
    Dim TDS As New DataSet()
    Dim ExtTable As DataTable = TDS.Tables.Add()
    Dim ConnTbl As DataTable = TDS.Tables.Add()
    ConnTbl.Columns.Add("Ext", GetType(String))
    ConnTbl.Columns.Add("Change", GetType(String))
    ConnTbl.Columns.Add("Status", GetType(String))
    ConnTbl.Columns.Add("CallID", GetType(String))
    ConnTbl.Columns.Add("Caller", GetType(String))
    ConnTbl.Columns.Add("Type", GetType(String))
    ConnTbl.Columns.Add("Outbound", GetType(String))
    ExtTable.Columns.Add("Ext", GetType(String))
    ExtTable.Columns.Add("Group", GetType(String))
    ExtTable.Columns.Add("Desc", GetType(String))
    ExtTable.Columns.Add("Reg", GetType(String))
    ExtTable.Columns.Add("Status", GetType(String))
    ExtTable.Columns.Add("Type", GetType(String))
    ExtTable.Columns.Add("", GetType(String))
    Dim d As DN() = ps.GetExtensions
    For x = 0 To d.GetUpperBound(0)
    Dim ext As TCX.Configuration.Extension = d(x), Grp As String = ""
    If ext.Groups.Length > 0 Then Grp = ext.Groups(0).Name
    Try
    ExtTable.Rows.Add(d(x).Number, Grp, d(x).ToString, CInt(ext.UserStatus), CInt(d(x).IsRegistered), "Ext", "")
    Catch ex As Exception
    End Try
    Dim conns As ActiveConnection() = d(x).GetActiveConnections()
    Dim AC As ActiveConnection
    For Each AC In conns
    Try
    ConnTbl.Rows.Add(AC.DN.Number, AC.CallID, AC.LastChangeStatus, CInt(AC.Status), AC.ExternalParty, "Call", CInt(AC.IsOutbound))
    End Try
    Next
    Next
    Try
    ExtTbl.Dispose()
    CnnTbl.Dispose()
    End Try
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    C# version. You should know how to convert is to VB .NET ;)
    try
    Extension ext = PhoneSystem.Root.GetDNByNumber("100") as Extension;
    String nameofthestatus=ext.CurrentProfile.Name;
    bool isThisExtensionInDNDMode = (ext.UserStatus==UserStatusType.Away)
    bool doesThisExtensionHasRegisteredDevices = ext.IsRegistered;
    ... and then do everything you want
    catch
    it is not an "extension"...
    Simpler, isn't it?
    P.S. blog provides complete information about API...
