Ghost System Extensions
Discussion in '3CX Phone System - General' started by garn, Jul 12, 2018.
  1. garn
    Jul 17, 2017
    18
    I have a few system extensions that I need to remove that are left over from Patton Gateways that have been removed; I don't see any way to remove them via the UI.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,063
    57
    Unfortunately, you need to get 3CX support engaged. I had the same issue on v15.
  3. garn
    Jul 17, 2017
    18
    That was the route I started down, but then decided to try the message board first since every attempt to find a contact channel resulted in mentioning I needed to pay for support ticket...
    Not big on paying for support for what is clearly a bug or basic missing function!
    I'll see if I can find a direct number.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,919
    324
    Hello @garn
    Please note that you will need to create a support ticket in order to have this issue resolved.
