Gigaset C475IP - Can Not Receive Call
Discussion in 'Windows' started by meshad, Aug 5, 2009.
  1. meshad
    Aug 5, 2009
    41
    Registration ok. but after i ring to Gigaset C475IP from X-lite or any other VOIP client registration fail on Gigaset C475IP. but after sometimes it re-register.
    Gigaset S450IP - even can not ring to this series.
    Is there any problem on 3CX or phone problem? or supporting issue? dont know what is happening. frustrated!
    need help of any one
  2. Tugi2o
    Feb 20, 2007
    61
    which version of 3cx software do you use?
    i use 3 gigaset C475ip with 3cx and i have no problems...but i use a very old version (latest of v6).
  3. meshad
    Aug 5, 2009
    41
    im using 3CX V 7.1.6278.0 free version
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    install the last version 7.1.71 there is some bug in 7.1.6278.
