Gigaset N300i to cloud 3cx
Discussion in '3CX Phone System - General' started by Nick Harvey, Mar 19, 2018.
  1. Nick Harvey
    Feb 21, 2018
    15
    I have a new install with mainly 3CX Win clients, but one Gigaset N300i running 2 DECT handsets. Customer needs the N300i as it provides the SIP fallover ringer.
    Both the extensions go up and down many times a day. I'm trying to work out a VPN to the Google Cloud 3CX, but in the meanwhile is there any other way of making this more stable? SBC seems to be largely undocumented, so I cannot play with that option.
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    649
    104
    That' because Gigaset aren't supported for connections via SBC only VPN.
    If you want to use these with the SBC you could manually point the SIP registrar at the SBC for registration.
    Either way if using anything Gigaset to the cloud you need to tunnel the connection as these devices are not very security concious about the way they send their credentials.
  3. leejor
    10,068
    201
    I'm going out on a limb and assuming that the menu/GUI/options in that Gigaset are similar to the North American variant DECT/VoIP base station. If that's IS the case, then they should support STUN and have many of the same options to allow stable operation with or without the SBC.
    However, without VPN or an SBC, you may still experience one way audio if you programme more than one extension into the base. This will depend on how your router handles the audio packets.
    You describe the sets as going down many time a day, this is obviously not normal and you really need to determine why this is happening. Is there a pattern, time of day, after a given time-out? Use the 3CX Activity Log, or perhaps Wireshark, as there may be something else going on besides incorrect options. The fact that it registers, suggests that the majority of settings are correct.
    I have 5 of the Gigaset base stations, and locally, at least, they have never caused a problem.
  4. Nick Harvey
    Feb 21, 2018
    15
    Leejor, are they extensions to a remote 3CX or a local one? Mine are remote
  5. Nick Harvey
    Feb 21, 2018
    15
    So all I would need to do is to change the N300 setting from the FQDN of the remote 3CX to the local IP of the SBC? (assuming my SBC setup was good!)
  6. leejor
    10,068
    201
    Mine are local, but I've use many devices remotely to my 3CX setup. The Gigaset seem to provide all of the options needed to do STUN IF I were to install the Gigaset remote to the PBX. As I said, the issue that comes up most often, when doing this without VPN or an SBC is one-way audio when more than one extension is used at the same location. In many cases, using PBX Delivers Audio, in the extension setting can help with this.
    You seem to be having an issue that is (perhaps?) network related, or, the Gigaset is not re-registering often enough. You need to figure out what is causing it to stop communicating/dropping.
  7. leejor
    10,068
    201
  8. eddv123
    Aug 15, 2017
    649
    104
    I've not ever used Gigaset but have used other third party products like Gateway's and un-supported DECT bases and it' worked fine.
    Put it this way theres nothing set on the SBC that will block third party traffic.
    You just can't take advantage of plug and play provisioning with the SBC.
  9. eddv123
    Aug 15, 2017
    649
    104
