Gigaset n510 IP Pro - Phone number after call pickup
Discussion in '3CX Phone System - General' started by BSAEMS, Nov 7, 2016.
  1. BSAEMS
    Nov 7, 2016
    Hi all,
    We've configured several n510's and those are working fine, but call pickup.
    I've configured a ring-group and when this is called, I pick-up the ring-group with a Gigaset S650H .
    For 1 second I see the outside calling number, but then the ring-groups name shows up.
    Is it possible to get the outside calling number continuously showing in display?
    Thanks,
    John
