Gigaset N510 Provisioning File
Discussion in '3CX Phone System - General' started by JonnyM, Nov 16, 2017.
  1. JonnyM
    May 17, 2010
    81
    5
    Just a couple of things with the N510 provisioning file. This value seems to always be used for the device name on the network, regardless of what the 'friendly' name used in 3CX is:
    Code:
    <SYMB_ITEM ID="BS_IP_Data3.aucS_NETWORK_DEVICENAME" class="symb_item" value=""gigaset-N510""/>
    I think if no value is supplied by the provisioning file then the device just uses whatever is set in the web UI, which would be preferable than having it overwritten by something generic.
    Secondly, the names assigned to extensions seems to only use the value from the surname on the extension:
    It would be good to have some control over this, for our use case it makes more sense to take the first name.
    The above is as tested in 15.5.6354.2
    #1 JonnyM, Nov 16, 2017
