Gigaset N510 Updating Profiles results in "No line Configured"
Discussion in '3CX Phone System - General' started by John Marshal, Nov 6, 2017.
Tags:
  1. John Marshal
    Nov 6, 2017
    Hi to All,
    I've Installed a 3CX 15.5.5 free version over Windows Server 2008 R2 SP2, Start my tests with a Gigaset n510 and a single voip trunk. All Fine, Just Two DECTs.
    Problems start adding a Second Gigaset N510, It responds with "No line Configured" each time try to update profiles from n510's web interfaces. Can't understand what's wrong with configs.
    Could be a licence limitation?
    Many thx.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
  3. John Marshal
    Nov 6, 2017
    Yes, same guide I've used for first installation. Can't understand why it intend for "no line configured".
  4. leejor
    10,368
    228
    I have a number of the N610 base stations with multiple handsets each, all configured manually. Just wondering if you are adding an additional base, or an additional handset to the base, with a different extension number.
    If it is the second, then you are attempting to add a second extension number to an existing MAC address. Once a a second extension is created in 3CX, you should be able to manually add that in the Gigaset base. However if it re-provisions, it will revert to a single (the original) extension number. You will run into the same issue as someone attempting to automatically provision a VoIP set with various extensions on different keys without manually modifying the configuration file.
    Please correct my assumptions, if incorrect.
