Gigaset N720 DM PRO 3CX Phonebook
Discussion in '3CX Phone System - General' started by GoPiTM, May 15, 2015.
  1. GoPiTM
    May 15, 2015
    9
    Has anybody been able to get the 3CX phone book on the DECT handsets of a Gigaset N720 DM PRO?
    Many thanks
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    As far as I know is this not possible.
    You have to use the Yealink W52P.
  3. GoPiTM
    May 15, 2015
    9
    The problem is that the Yealink is not a multi cell DECT or can phone from one Yealink W52P "roam" to another Yealink W52P?
  4. complex1
    Jan 25, 2010
    752
    38
    Do you want something like this?
    http://forum.yealink.com/forum/showthread.php?tid=2399&highlight=roaming
    http://forum.yealink.com/forum/showthread.php?tid=3086&highlight=best+base
  5. Mitch76
    Jun 14, 2013
    Bumping this thread.
    Having the same question. Have a N720 system up and running, works perfectly on 3CX, but without the phonebook.
    Meanwhile, 3CX now officially supports the N510 including phonebook, wondering if there is a N720 solution upcoming as well.
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    As far as I am aware, even though the N510 is in the supported list, I believe it does not pull the contact list from 3CX, the only option you have I think is LDAP.
  7. rb1
    rb1
    Nov 17, 2016
    17
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    281
    Hello @rb1
    Please note that even if these phones are supported by 3CX the phonebook will not work as these phones load the phonebook directly to handset and not the base station. For these phones to have a working phonebook with 3CX they need to load the phonebook to the base station which they cannot do.
