Implemented Gigaset N720 IP Pro Device Support
Discussion in 'Ideas' started by Melvin_XIII, Mar 30, 2017.
Implemented Gigaset N720 IP Pro Device Support 5 5 4votes
5/5, 4 votes
What MultiCell DECT solution do you use?
  1. Panasonic (KX-UDS124 or other)
    0 vote(s)
    0.0%
  2. Gigaset N720
    100.0%
  3. Snom M700
    0 vote(s)
    0.0%
  4. Cisco (one of many)
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Melvin_XIII
    Oct 25, 2016
    38
    Currently the only by 3CX supported MultiCell DECT System is the Snom M700.
    Due to a better compatibility with other third Party DECT Devices (eg. Jabra GN9125) and a huge selection of compatible DECT Handsets form Gigaset, I would suggest the N720 should be added as an officially supported device to the 3CX Library of supported devices.
  2. rb1
    rb1
    Nov 17, 2016
    18
    Wir nutzen mehrere Gigaset N510. Allerdings ist das Büro schon fast zu groß. Wir sind testweise auf das Gigaset N720 Multicell system Umgestiegen. Dieses system kann genau das was wir wollen. Allerdings fehlt der Support für 3CX. Wir würden es gerne im CTI Modus nutzen können.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    This has been implemented in V15.5
