Global default Windows Client to Deskphone (CTI)
Discussion in 'Windows' started by AndrewM, Sep 29, 2017.
  1. AndrewM
    Sep 29, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,455
    355
    Hello @AndrewM
    Please note that when creating an extension the default setting for an extension is set to softphone. This cannot be changed. You can however select multiple extensions from the extensions tab using the Ctrl or Shift button, click on edit, navigate to the phone provisioning tab and select the option for all extensions. Press ok and the change will apply for all
  3. AndrewM
    Sep 29, 2017
    Hi Yiannis,
    Thank you for your quick and helpful reply.
    Andrew
