GMAIL SMTP and Log viewer
Discussion in '3CX Phone System - General' started by michaelbird75, Nov 30, 2014.
  1. michaelbird75
    Nov 30, 2014
    I have been reading a bit about Gmail SMTP configuration and I still cannot get this working.
    is this supported or not?
    If someone could clear this up or suggest another free SMTP service that would be very helpful. I do not have a local ISP that I can rely on for this...
    I also have been trying to download the log viewer but I get an error every time i try to get the link from the 3CX Phone System Updates tab. Its as if the link is no good. Are there direct links to this?
    Any help is appreciated.
    I have release 12 with a pro license.
    Mike
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    check to see if the log viewer exists already at
    "C:\Program Files\3CX PhoneSystem\Bin\Support\3CXBinLogViewer\3cxBinLogViewer.exe"
    I have tried to get Gmail SMTP working with my home UCM and never had any luck - or had long delays in delivery. I ended up using my ISP's info (Cox).
    You might also look at H-mail. It was recommended to me - but I never evaluated it. We have an internal SMTP Server that relays to our Office 365 account.
  3. michaelbird75
    Nov 30, 2014
    Thanks, I got the Gmail working and no problems so far.
    Still no luck on the log viewer, its not in the directory and is still not available in the downloads link.
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Gmail will block using SMTP server by 3CX phone system after a while, as they consider this usage as violation of Terms of use.
