GMS/voIP integration : escape sign
Discussion in 'Android' started by gauvins, Sep 8, 2010.
  1. gauvins
    Jun 30, 2010
    7
    Is there a way to route a call thru GSM without quitting 3CX. (e.g. Sipdroid will not process numbers ending with +) Essential feature whenever data communication is marginal.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    Yes you can already do this by going in your Profile Settings > Integration > Redirect Normal calls and disable it.
    Then you would need to Re-Start the 3CXPhone for the effect to take place.
  3. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    I think he's looking for a way to do it on a per-call basis. He points out that by adding a + to the end of a number routes it to SipDroid, else it just goes to mobile. Another way (used by CSipSimple) puts up a selector (VoIP or Mobile) after tapping Call and before connecting the call. Something like that...
  4. LeonidasG
    Nov 19, 2008
    1,455
    92
    Ah well for a per call basis there is currently no way to do this.
    In the future we do plan to add new features, and i'm guessing that one would be a good start.
    But for now we are still fighting against fixing the most common issues on Android Phones so we can provide everyone with a Working 3CX Client, adding features will come after we have made sure that the client works on the majority of Android Phones out there.
