GMT to BST switch in Google Cloud Services
Discussion in '3CX Phone System - General' started by AlexDBarrett, Mar 27, 2017.
  1. AlexDBarrett
    Jan 25, 2011
    71
    9
    The systems in GCS work on UTC (GMT).
    Appreciate some suggestions on how best to approach the GMT to BST and back to GMT change.
  2. AlexDBarrett
    Jan 25, 2011
    71
    9
    Tech Support response
    Unfortunately we cannot provide you with the commands as this is OS specific and not a part of 3CX Support, that being said the system administrator needs to adjust the time of the server.
  3. imerecom
    Dec 2, 2009
    21
  4. AlexDBarrett
    Jan 25, 2011
    71
    9
    Thanks imerecom.
    After a bit of hunting I believe I found it. dpkg-reconfigure tzdata
    Simple really.
