- Joined
- Mar 22, 2008
- Messages
- 1
- Reaction score
- 0
hello,
Goldennet ET 747 ip phone always reregisters.
18:54:55.578 ExtnCfg::updateContact [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
18:53:55.937 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]/11]
18:53:55.609 ExtnCfg::updateContact [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
18:52:55.421 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]/11]
18:52:54.109 ExtnCfg::updateContact [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
18:51:54.906 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]/11]
18:51:54.484 ExtnCfg::updateContact [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
I can call it from the soft phone but the ip phone is not able to place calls:
18:39:51.546 Call::Terminate [CM503008]: Call(9): Call is terminated
18:39:51.531 CallCtrl:nIncomingCall [CM502001]: Source info: From: 9; To: "11"[sip:[email protected]];tag=7625d7f9"015773854365"[sip:[email protected]]
18:39:51.531 CallCtrl:nIncomingCall [CM503012]: Call(9): Incoming call rejected, caller is unknown; msg=SipReq: INVITE [email protected] tid=39eca56690e930310f013f296a75be3a cseq=INVITE [email protected] / 2 from(wire)
18:39:50.265 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.178.29:5060;branch=z9hG4bKf1d77f07a781cace6d82c34cda2495a9
Max-Forwards: 70
Contact: [sip:[email protected]]
To: "015773854365"[sip:[email protected]]
Call-ID: [email protected]
CSeq: 1 INVITE
Subject: SIP Call
Content-Length: 0
18:39:50.265 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE [email protected] tid=f1d77f07a781cace6d82c34cda2495a9 cseq=INVITE [email protected] / 1 from(wire)
18:39:49.046 ExtnCfg::updateContact [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]/1
The ip phone is directly connected to the Pc via network cable and can ping the Pc and the internet router - connectivity looks good.
Any ideas for help?
Max-Forwards: 70
CSeq: 1 INVITE
Subject: SIP Call
Content-Length: 0
Any ideas for help?
