Google Cloud Hosting - |Email
Discussion in '3CX Phone System - General' started by ccomley, Nov 23, 2016.
  1. ccomley
    Apr 6, 2011
    92
    This is a Hint-n-Tip post.
    3CX documentation confirms that Google Cloud compute-engine hosts will NOT be able to send outbound mail on any of the traditional SMTP ports, esp not port 25 which is what 3CX expects to use.
    I've set up my firewall at the office to accept email on port 26. (well, technically it accepts traffic on port 26 and passes it to port 25 of the mail server, which never knows anything odd happened).
    I was playing with IPTables on the Google hosted Debian to re-route outbound port 25 traffic to port 26 but couldn't get it to behave. Then I found a hidden setting in the 3CX PARAMETERS table which tells 3CX to use port 26 to start with. The parameter is
    MLSRVPORT
  2. mahe23
    Apr 28, 2009
    23
    Here is an additional hint:
    1. You can use a smtp provider: www.smtp2go.com
    2. Create a free account. They use the port 2525 which is open at Google Cloud
    3. Go to 3CX Mail-Settings and enter : mail.smtp2go.com:2525 as the Mailserver
    4. Add your ID and PW for SMTP2go.com. It works with/without SSL/TLS
    5. Now you can receive your provisioning files by mail.
  3. mo@closetrak.com
    Feb 9, 2016
    I'm going to try it now
  4. salomaowk
    Jan 23, 2017
    It works!
    Thank you all for this information!
