Google Cloud Instructions
Discussion in '3CX Phone System - General' started by christensen143, Feb 18, 2016.
  1. christensen143
    Jan 20, 2016
    Hello Everyone,
    I searched the forum and didn't seem to find any information to help with setting up Google Cloud firewall rules specifically port forwarding. Maybe I'm missing something but when I set it up in Google Cloud and setup the firewall settings I was unable to get it to work. I tried doing the port forwarding that Google suggests in this doc:
    https://cloud.google.com/compute/docs/p ... orwarding/
    But the doc is not very intuitive. My question is, does anyone have a tutorial hidden away on getting this working?
    Thanks,
    Chris
  2. jfletcher
    Nov 22, 2011
    16
    I'm pretty sure if you create it using the PBXExpress option the firewall is auto set for you. It is also much easier to build the 3CX system using the PBXexpress approach.
