Google Cloud Messing Push Notification
Discussion in '3CX Phone System - General' started by AmazingFacts, Apr 9, 2014.
  1. AmazingFacts
    Mar 11, 2014
    Hi Everyone,
    I've successfully setup my Android phone to work on the LAN and when out of the office. I've also configured the Google Push notifications as documented here: http://www.3cx.com/docs/configuring-google-push/
    How do I know if these notifications are working or not?
    Thank you!
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    736
    113
    @AmazingFacts
    Basically, let your phone go to sleep/idle/lock and then call it (via the 3CX extension/app). If it wakes up, push is working.
  3. cobaltit
    Mar 22, 2012
    736
    113
    @AmazingFacts
  4. Deepest
    Nov 9, 2012
    45
    Hi There
    The google push service is there so you do not need the 3cx phone for android app running and using up battery.
    When you get a call you will get a push message stating incoming call from (number).
    If you click on the message your android device will start up the 3cx phone app register and connect the call.
    To test this exit completely from the 3cx app and get a colleague to call your extension.
    Cheers
  5. AmazingFacts
    Mar 11, 2014
    Thank you everyone! It appears that I do have it setup correctly.
