Google Cloud + remote phones using RPS
Discussion in '3CX Phone System - General' started by regomotiv, Mar 26, 2018.
  1. regomotiv
    Sep 15, 2009
    49
    I've read this:
    https://www.3cx.com/community/threa...tes-hop-on-the-pbx-express.48134/#post-195064
    I've watched this:
    https://www.3cx.com/3cxacademy/videos/intermediate/configuring-remote-extensions/
    I also PM'd @YiannisH_3CX
    This 3CX article makes no mention of incrementing ports:
    https://www.3cx.com/docs/manual/configuring-ip-phones/#h.ul2fzupi6t22
    Question is:
    1) Do we need to increment the ports for each remote phone
    2) Do we need port forwarding rules for the phones that got incremented in step #1
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    384
    35
    Hello @regomotiv
    In case of remote stun provisioning, if phones are behind the same public IP address, then you'll need to use different SIP & RTP ports for each phones, so yes, in this case you'll need to increment the ports. You'll also need to properly port forward the above ports to each phone on the remote firewall.
  3. regomotiv
    Sep 15, 2009
    49
    Hi @mariosM_3CX
    With multiple phones some "work" will be required at the firewall (port fwd rules, reserved IP address etc)
    Thanks for the reply.
  4. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    703
    101
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,823
    138
    I have had success, currently with 4 phones, at a remote site. Each one with incremented ports - but nothing changed on the remote firewall.
  6. leejor
    10,112
    203
    A lot can depend on the particular router, used at the remote site. Some seem to be able to "keep track" of which ports go to which device, others have problems, which can result in "no audio" or "one way audio" issues. The real test comes when calling from extension to extension at the remote site. In many cases, enabling PBX Delivers Audio in the 3CX the extension settings, can help.
