Google Voice Support
Discussion in '3CX Phone System - General' started by sigertronic, Jul 20, 2009.
  1. sigertronic
    May 30, 2009
    9
    Are there any plans to implement a Google Voice Gateway similar to that for Skype? I know G Voice is still in its infant stages, but it would definitely represent additional flexibility for an IP PBX.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    ...and support for video?
