Got REGISTER for foreign registrar error
Discussion in '3CX Phone System - General' started by Kevin Burns, Aug 16, 2017.
  1. Kevin Burns
    Apr 3, 2017
    43
    I get this error 10 times a minute and I do not know why. I am running 3cx 15.5 on a windows 10 machine with static ip
    10,758
    286
    Nothing more in the log? Verbose (detailed logs) enabled? Anything not working?
  3. Kevin Burns
    Apr 3, 2017
    43
    Every so often internal calls will cut out and sometime when an external number calls in they are met with a verizon message and cant even reach 3cx, but then they will call back and get through.. Sorry I definitely should have included that.
  4. leejor
    10,758
    286
    Is Verizon the VoIP provider? Is this a new issue, or has it been this way since...upgrade, day one, firmware/hardware change...
    Internal issues and the trunk issues may be unrelated. Does the provider say they are having any issues sending calls to you?
  5. Kevin Burns
    Apr 3, 2017
    43
    Thats the funny part. 888VOIP is our provider. This is a new issue, the voip provider didn't say they were having any problems. I have a remote session scheduled with them for tomorrow, but this literally came out of the blue. The only change that has been made to the system in the past 2 weeks was the upgrade of the firmware for one of our Yealink extensions, but nothing more than that
  6. leejor
    10,758
    286
    The Verizon message is interesting if it is happening enough to be related. Are Verizon customers getting this, perhaps not getting routed through to your provider. Is it just a "your call can't be completed at this time" recording or something else? Is it consistent? Unless all trunking into your provider originates with Verizon everyone shouldn't get this.
    #6 leejor, Aug 17, 2017
  7. complex1
    complex1 Active Member
    Jan 25, 2010
    789
    45
    As far as I know this message occur if the (remote) phone and the PBX differs in the “Local SIP domain”
    e.g. “Local SIP domain” contain an IP address and the phone “Server Host” contain the FQDN of the PBX.
    Kevin Burns likes this.
