GPX-2000 phones go to sleep
Discussion in '3CX Phone System - General' started by rlaney, Nov 27, 2007.
  1. rlaney
    Nov 27, 2007
    12
    I'm a newby setting up the system. Configured 2 Grandstream GPX-2000 phones. They registered and I was able to place calls from each to the other.
    Problem is that they appear to go to sleep after 3 - 5 minutes and I have to reboot the phones to get them to work again. This is consistent. Also, when this happens there is no indication on the phones' displays that there is anything amiss.
    I would appreciate any advice.
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    GXP-2020 nearly the same but hereit take much more time (about a day) then i can not make outgoing calls. cannot find reregistering in the log.
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    i have a GXP2000 and i found the same issue... the way i found to work around things was to change the max re-registration time on phone config(to about 41 or 42 days). After that of corse i have to reboot the phone...
    Cheers
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    not nice but a work around
    whats about a remote reset from PBX ?
    Andy
  5. rlaney
    Nov 27, 2007
    12
    Thanks all for your help. I've discovered that when I turn off the (XP) firewall the phones function properly. I don't understand why the firewall effect would be delayed.
    So, this leads to another question, does anyone know which ports I need to open in the firewall?
    Thanks again for your help.
  6. silentfun
    silentfun Member
    Dec 11, 2006
    364
    List of default ports used by the 3cx phonesystem:
    5060 (stanard sip port) TCP/UDP
    5061 (secondary sip port) TCP/UDP
    5480 (portgre) (only on local machine)
    5481 (apache) (only on local machine)
    5482 (media server) (only on local machine)
    3478 (STUN Server) TCP/UDP
    7000-7500 (Default port for internall calls) (only on local machine)
    9000 - 9003 (ports for external calls through VOIP Gateway) UDP
    10000-20000 (RTP ports) (Used if no stun available for audio)
