GPX-2000 Registered but No Transfer
Discussion in '3CX Phone System - General' started by tomperanteau, Dec 6, 2007.
  1. tomperanteau
    Dec 6, 2007
    I have configured my GPX- 2000 phones (2 of them). They both show green on the status page. I can dial out on them just fine. Problem is that when I call into the system and press the appropriate key (1 is routed to extension 101), I get the forwarding message and then the recording that the extension is not available. If I route to VM, it will then go to VM. The two extensions cannot ring each other either.
    Any ideas?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    No logs - no ideas :)
    Sorry, just kidding. But it's true that logs can give us some hints.
  3. tomperanteau
    Dec 6, 2007
    Logs...
    Here is the log. As you can see it only says "failed". When I attempted an extenton-to-extension call it did not ring.
    1 2007-12-06 08:34:44 17144184015 800 Answered 00:00:32
    2 2007-12-06 08:42:47 101 102 Failed
  4. tomperanteau
    Dec 6, 2007
    I Figured it Out
    Thanks, but nevermind. I had the "STUN server:" field populated. When I deleted the server that was in that field, it started working..
