Grandstream 2020 Registration Issue
Discussion in '3CX Phone System - General' started by lonestar.computer, Jan 27, 2008.
  1. lonestar.computer
    Jan 27, 2008
    16
    I just setup a new pair of Grandstream 2020's and a newly downloaded free copy of 3CX(ver 5.03790.0). I configured three new lines - two for the 2020's and 1 3CX soft phone. The problem is that none of these will register. I think they are all setup correctly SIP IP and passwords - everything else is default. Any suggestions?
  2. blackflash76
    Dec 18, 2007
    9
    Maybe you should turn off Firewall on the computer where 3CX is installed.
  3. matthijsolislagers
    matthijsolislagers New Member
    140
    Can you post your server log please.
  4. lonestar.computer
    Jan 27, 2008
    16
    Thanks for the posts;
    I have turned off the firewall but authentication is failing. See logs below:
    14:37:31.200 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.14 tid=687ffb94a37aff6a cseq=REGISTER contact=rodney@192.168.1.8:5060 / 10002 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    14:37:30.900 printDetailedInfo [CM502001]: Source info: From: "Rodney Whiddon"[sip:rodney@192.168.1.14];tag=303c209f33b4bd6a; To: [sip:rodney@192.168.1.14]
    14:37:30.900 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.1.14 tid=687ffb94a37aff6a cseq=REGISTER contact=rodney@192.168.1.8:5060 / 10002 from(wire)
    I did try adding a softphone and I used the "use 3cX authentication" and it conected OK and the server showed the extention in use. When I tell the soft phone to connect using the "SIP Server /voip provider" it will not connect.
    I have tried changing the password to null and to other values - no luck. I am assuming the grandstream 2020 does work with this pbx???
    I tried stopping the 3CX service and restarting
  5. blackflash76
    Dec 18, 2007
    9
    I've simulated your error. When you config your GXP2020 you have to insert in the field SIP-User ID the nummber of the extention and not the name.
  6. lonestar.computer
    Jan 27, 2008
    16
    I got it to work. Changed the SIP ID, auth ID and auth password to match the station #.
