Grandstream 4004 and faxing
Discussion in '3CX Phone System - General' started by pogue1000, Aug 4, 2011.
  1. pogue1000
    Jun 1, 2011
    21
    I am trying to get the grandstream 4004 setup to fax per this article http://www.3cx.com/blog/voip-howto/faxing-gxw-4004-4008-4024/
    I seem to have everything setup right but it wont provision. I cant see it in the pstn devices.
    One thing interesting is once i go back into the setup of the 4004 the field where i enter the provisioning server is blank
    I enter 192.168.1.10:5000/provisioning
    If i hit save its there, but once i reboot and go back its blank
  2. pogue1000
    Jun 1, 2011
    21
    one thing interesting is it look like it did kind of provision because it has my fax extensions if i go into the fxs ports tab on the gateway web config
    well one thing i see when looking at my log is that i am getting an error on my 3cx that the credentials dont match.
    I dont see where to add the password on the grandstream though.
