Grandstream 400x/4024 provisioning
Discussion in '3CX Phone System - General' started by mixig, Sep 18, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    I tested provisioning for grandstream ata and what bothers me is that unused ports can`t be disabled, e.g. 4008 model, i am having 4 users, I configured 4 ports and the last 4 can`t be disabled, i must put some extension on that ports... I can put some dummy extension on that ports which will not be in use? is there any other smarter solutions?
      File size:
      17.2 KB
      361
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    The smartest and the only solution is to create an extension for each and every port that your FXS has. Even if that port is not used for the moment. If they are not used, this will not affect in anyway your PBX and if you want to use them in the future this will be very easy for you.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    yep, better than my solution, thanks...
