Grandstream Budge Tone 200
Discussion in '3CX Phone System - General' started by andrewseni, Jan 15, 2013.
  1. andrewseni
    Aug 14, 2008
    17
    Has anybody managed to provision GrandStream Budge Tone 200 (3CX V9)? I am having no success.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Option 66 - Use default Grandstream template (no PnP), or manually input in the CONFIG server field of the web interface the proper path based on your Server IP, port used etc.
