Solved Grandstream DP750
Discussion in '3CX Phone System - General' started by elbolo, Mar 15, 2018.
  1. elbolo
    Mar 11, 2018
    I know the grandstream dect system dp750 is not yet supported,
    but can i provision/configure it manually, or there is a guide i can follow.
    My configurtion is
    3cx latest release running on a qotom mini pc, everything is running inside the lan, i need to configuare a bese with 2 handsets.
    thanks in advance
  2. dominoit
    Mar 16, 2018
    Good timing on the post, I just set up a 3CX on one of my local servers and I picked up some grandstream GXP1630's which configured nicely. I also bought a DP720+DP750 to try out but I also don't see a way to configure them or an option to custom add these phones.
    I'm almost certain there must be a manual way to add a config but I'm not sure how. This platform is built on asterix and they just need a text file config to be added but I'm not sure how to go about that on 3CX. I'm very new to the whole SIP trunking and PBX scene, just trying to learn this stuff.
    [​IMG]
    #2 dominoit, Mar 16, 2018
  3. elbolo
    Mar 11, 2018
    GOT IT
    I finally find a solution to provision the dp750 base with 3cx 15.5
    googling around i find a guide for dp715 here:
    https://www.3cx.com/community/threads/grandstream-supported-phones.50807/
    then following the link i downloaded the file:
    3CX_Templates_v1.4_V15.zip
    inside there's a template for the dp750,
    added it through the web interface
    Settings ---> Template ---> Add Template
    :D
    now it works directly plug and play
