Grandstream GXP 1200
Discussion in '3CX Phone System - General' started by matan, Feb 11, 2010.
  1. matan
    Jun 24, 2009
    7
    Hi everyone,
    I need to make a factory reset on my Grandstream GXP 1200. When I enter in the Config--Factory reset menu, there is a blank field. Take a look at the photo:
    [​IMG]
    So, what I've to insert into the field??
    Any help is appreciated.
    Kindly Regards.
