Grandstream GXP-2000 and Unregister on reboot
Discussion in '3CX Phone System - General' started by kelddamsbo, Feb 22, 2007.
  1. kelddamsbo
    Feb 22, 2007
    24
    If I activate "Unregister On Reboot" on my Grandstream GXP-2000, it will not come online again.
    It works okay on Asterisk.
    Is it not supported on 3CX ?
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    I have just tested it with the same Grandstream phone. It works with our phone. It briefly unregisters and re-registers again.
  3. kelddamsbo
    Feb 22, 2007
    24
    Strange, what firmware are you using on your Grandstream ?
    What version are you using on 3CX ?
  4. Anonymous
    Anonymous Guest
    Try to decrease the re-register timer, generally these are set to 3600 or 240 seconds.
    Reduce it to something like 5 sec, see what happens. Perhaps it gives up to soon due to latency in your network.
  5. kelddamsbo
    Feb 22, 2007
    24
    My network is okay, but thanks anyway for the lead.
    I found the problem, my server for telephony was too slow.
    When I moved 3CX from a P3 1 GHz to a P4 D 2,8 GHz it solved the problem.
