Grandstream GXP-2020
Discussion in '3CX Phone System - General' started by darryla, Nov 6, 2007.
  1. darryla
    Oct 11, 2007
    30
    Has anyone tried using a Granstream GXP-2020 with the 3CX as a remote extension?
    I know the GXP-2000's work as remotes. How about the 2020's?
    Just looking for some opinions.
    Today, I decided to return my Polycom 650's. It was absolute hell trying to get them to work right as remote extensions. Besides all of the other problems, the thing that killed their long term viability was the fact that you have to hard code the WAN IP into the config files. That's not going to work if the phone gets moved or the dynamic WAN IP changes.
  2. ktikoft
    Jun 22, 2007
    59
    The 2020, use the same firmware so they shoudl work although I havenot tried it myself.
    did you see the new 2010's ?
