Grandstream GXP1610
Discussion in '3CX Phone System - General' started by vitor, Jan 3, 2019.
  1. vitor
    Jan 3, 2019
    10
    hello
    i have installed the latest 3cx pbx version
    Product Standard Annual
    Version Number
    15.5.0
    and using GXP 1610 Version 1.0.4.82, but I have noticed each time the phone register or I do some configuration changes it generates a incoming call... like a validation...
    is this a bug?
    its possible to remove this feature?
    thanks
    Vitor
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
  3. vitor
    Jan 3, 2019
    10
    hello Yiannis
    its simple upload the firmware file?
    and do the provision? no need to do dhcp change etc?
    thanks
  4. YiannisH_3CX
    May 10, 2016
    7,783
    564
    You can update the firmware of the phones through the management console if the phones are registered. Navigate to Dashboard / Updates and make sure the firmware is downloaded. The through the phones tab you should be able to upgrade the firmware.
  5. alan nogueira
    Jan 9, 2019
    9
    Hello Victor,
    There are many ways to do it, explained at 3cx tutorials.
    The easiest one is loggin into your 3cx panel -> Phones -> select your Grandstream in the list (you have to provision it first) -> then click "Firmware" button. It will install automatically.
    Here´s the link: https://www.3cx.com/sip-phones/manually-provision-supported-grandstream-gxp/
    Unfortunately, it didn´t work for me.
    The way i found was changing the update server in the phones gui:
    1) open web browser and type your Grandstream´s IP address
    2) the default user / password is admin / admin (if you have provisioned it in 3cx, the user is admin and the password you can see at the 3cx control panel -> extensions - click in the "password" button and use the one listed in the "Phone pwd" collumm - ITS DIFFERENT FROM YOUR EXTENSION PASSWORD).
    3) Click "Manteinence" -> Upgrade and provisioning
    4) At "Firmware" change "Firmware Upgrade via" to "HTTP" and Firmware server Path to "firmware.grandstream.com" and click "Save and apply".
    5) Your phone will reboot and install the firmware. It will take several minutes...
    6) After installing, factory reset your phone https://www.3cx.com/sip-phones/factory-reset-grandstream-gxp/
    7) Then you should provision your grandstream again (the full tutorial for this model: https://www.3cx.com/sip-phones/grandstream-gxp16-series/
    Have a good luck, if you have any doubts please ask
    Alan
