Grandstream GXP2110 phone book
Discussion in 'Windows' started by jtrolinger, Jan 27, 2011.
  1. jtrolinger
    Mar 3, 2010
    The new Grandstream GXP2110 will not take a download of the 3CX phone book. The 2010's work with the phone book. We have working 2010's on TFTP and HTTP. Neither TFTP nor HTTP work with the 2110. 2110's never finish the boot process.
    Good new is that it is possible to log on to the phone and change the setting back to 'no' then reboot the phone.
    Edit: Looks like this is a GXP2110 problem. See http://forums.grandstream.com/forums/index.php?board=122.0
  2. GSsupport
    Jan 31, 2011
    17
    Hi jtrolinger,
    1) Can you please tell us which firmware are you using in your GXP2110?
    2) Are you using any special characters (%, - ...) in LastName and/or FirstName fields or phone numbers with more than 10 digits?
    If yes, please remove them and try again
    3) Can you please describe the steps you are following to use xml phonebook?
    B. regards,
    GSsupport
