Solved Grandstream GXP2124 phonebook 3cx (contacts)
Discussion in '3CX Phone System - General' started by Jor3cx, Nov 14, 2017.
  1. Jor3cx
    Oct 26, 2017
    13
    Does anyone know if it's possible to use the phone book of 3cx, on a Grandstream GXP 2124?
    Now I see a phone book or a group. The 3cx contacts are not visible.
    Grandstream GXP 2124 Firmware Version 1.0.8.6
    3cx V15.5
    Thanx!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Jor3cx
    If the phone is auto provisioned as local using the default template then you should be able to see the PBX phonebook. The contacts should be visible into the Local Phonebook option.
  3. Jor3cx
    Oct 26, 2017
    13
    After provisioning again i can see the phonebook.
    Thanx
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Glad the issue is resolved :)
