Grandstream GXP2135
Discussion in '3CX Phone System - General' started by Matthew Lidbetter, Feb 8, 2018.
  1. Matthew Lidbetter
    Jan 26, 2018
    13
    With the latest release of 3CX providing support for Grandstream phones is there any chance of the GXP2135.
    I am migrating existing Grandstream UCM systems to 3CX and it would be great if we don't have to replace handsets.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,610
    243
    If any chance is defined as even the remotest possibility then yes considering the blog post says BETA support for GXP21XX and GXP2135 falls in that category. But you don't need to replace the phones as many folks were using GS phones before and GS provides templates for 3CX.
  3. Barry O'Reilly
    Feb 9, 2018
    We've been using 2135's with 3CX for a couple of years, just had custom templates.
    Had to upgrade the phones to firmware mentioned here after SP3.
    https://www.3cx.com/support/phone-firmwares/
    This firmware is later than the current version Grandstream have put out and probably still a Beta version. Upgraded to SP3 today and all the phones decided to start ringing themselves until we upgraded firmware and provisioned the phones with the newly supported templates. No issues yet but only been an hour
  4. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Matthew Lidbetter
    Just to confirm this. The devise is supported in SP3 with a supported template.
  5. Matthew Lidbetter
    Jan 26, 2018
    13
    Thank you - I hadn't seen it in the supported list - it is not in numerical sequence.
    Are there any plans to support the Grandstream DECT DP750
  6. elbolo
    Mar 11, 2018
    there's news about grandstream dect750?
    Could we maybe provision it manually, someone can help?
    thanks in advance
