Grandstream gxv3149 issues
Discussion in '3CX Phone System - General' started by dragonfire, Feb 5, 2010.
  1. dragonfire
    Jan 6, 2010
    I'm experiencing 2 issues with this phone and I'm not sure if its the pbx software or the phone itself.
    The first problem is that when the extension goes idle it stops working altogether. No one can dial the extension from the outside. During the first 5 minutes of registration before idle its works fine.
    Second problem is that when video is enabled on the phone, the audio stops working altogether. To get audio back I have to disable video.
    Anybody have any ideas? fixes?
  2. mbulles
    Jan 18, 2010
    15
    I'm using a GXV3000 and a GXV3140 both have the latest firmware and i'm not experiencing any problems using 3CX v7.1
  3. StaffKB
    Jan 5, 2010
    97
    Regarding your first question:
    Please ensure that you don't have a Firewall Device that is mis configured or doesn't have Correct NAT and PAT. Try disabling the firewall. Also since this is an unsupported phone please ensure that there isn't an option for the device to go on standby after x amount of minutes.
    Regarding your second issue:
    Since 3cx doesnt support Video codecs kindly ensure that the Devices arent bound to the media server. Do this by ensuring that the PBX Delivers Audio option is disabled.
    Please take a look at the following forum post >> http://www.3cx.com/forums/use-of-videophone-with-3cx-5222.html
    Regards,
