GrandStream GXV3175 Phone**WORKS MANUAL CONFIGURATION ONLY
Discussion in '3CX Phone System - General' started by HurdIT, May 9, 2011.
  1. HurdIT
    Apr 13, 2011
    11
    Has anyone setup the GXV3175 Phone with 3CX version 10 RC1?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Re: GrandStream GXV3175 Phone
    It works no problems. Provisioning with the Video phones doesn't work like the standard GXP21XX phones though.
  3. HurdIT
    Apr 13, 2011
    11
    Any notes on how to provision the phone??
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Log into the web interface, set up the extension in the accounts tab. A few notes to remember.
    DialPlan needs to be set to: { x+ | *x+ | *x+*x+ } or you will find dialcodes hard to work with as well as extension numbers.
    Enable Call features has to be off if memory is correct. then apply your settings. You don't need to reboot.
    Aside from these settings you will be all setup. There web interface has a lot of options and you can get lost in it.
  5. HurdIT
    Apr 13, 2011
    11
    I have done the updates and the phone works. Also has anyone gotten the multiple like occurrences to work on the phone similar to the Yealink phones? It's the check-box under Forwarding Rules called [x] I want to be able to accept more than 1 call at the same time - used Phone Status.
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    I haven't, but when I get in the office tomorrow I will mess around and see what I can find out.
  7. nbailey
    nbailey Member
    Jan 31, 2011
    359
    I played around with this today and so far it works with no problems. My only complaint with this phone is the delay when pressing the touch screen buttons, I have small fingers and find it hard at times to dial but other than that I like this model.
  8. amos.max
    Jul 8, 2009
    20
    Re: GrandStream GXV3175 Phone**WORKS MANUAL CONFIGURATION ON
    Gents,
    don't mean to hijack the conversation, just a quick Q in this context: has anyone by any chance tested/verified the GXV3175 via the SIP Proxy Manager?
    Also, by "works" I'm assuning that incudes video as well, correct?
    Thx in advance!
    Marcus.
