Grandstream GXW-4004/4008 attended transfer problem
Discussion in '3CX Phone System - General' started by amartini, Aug 27, 2008.
  1. amartini
    Dec 28, 2007
    17
    I have configured 1 grandstream gxw-4004 and 1 gxw-4008 with 3cx SBS.
    I have a one way audio problem when I use the attended transfer feature even in internal calls.
    Example:
    Extension 200 calls ext 201. ext 201 pick up the phone, press Flash key and call ext 202. Ext 201 hang up the phone. Ext 202 can't hear ext 200, but ext 200 can hear ext 202. I have the same situation from an external call.
    i attached the verbose log.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Please Be sure that you have Latest Firmware
    also please try to reset to factory set and reconfig again
  3. amartini
    Dec 28, 2007
    17
    I solved disabling RE-invite in any extension profile in 3cx. Is that correct?
    Thank you.
